ArcGIS Monitor 2025.0.1
549
7
09-07-2025 08:36 PM
AntonyMundanmanyPaul
I am planning to upgrade the Monitor 2024 to 2025.0.1 soon.
Keen to know if anyone successfully upgraded to 2025.0.1?
Sorry to ask as I had to roll back the 2025 upgrade due the bug BUG-000177693 for ArcGIS Monitor
I understand this has been resolved with 2025.0.1. Still want to double check with 2025.0.1 upgrade outcome.
Kind regards,
Antony
Craig_Lunde
I had issues with the database upgrading from having too large of a database over 9 billion rows. ESRI tech support had me delete all the data for the upgrade to complete.
MariuszZ_EPL
Before upgrade you need change config file .env in default path C:\Users\[serviceuser]\AppData\Local\ESRI\ArcGISMonitor\config-store-server
Set DB_QUERY_TIMEOUT=180
Big size database need more time to upgrade.
Craig_Lunde
Thanks for that tip, the problem wasn't a time out though. It consumed all the RAM and over 150 GB of drive space for query "ALTER COLUMN id TYPE BIGINT". ESRI support had me fix this bug wrong the first time so that could have been the issue too.
https://support.esri.com/en-us/bug/unable-to-display-metrics-for-all-registered-components-bug-00017...
Hi Craig,
Thanks for that.
Just checking, I should be doing this workaround before upgrade process to 2025.0.1?
or 2025.0.1 upgrade process taken care of this step?
Please let me know your thoughts.
Regards,
Antony
MariuszZ_EPL
Make sure the service account has permissions to modify the license file. It’s best to manually create the C:\Program Files\ESRI\License25.0 folder and assign the permissions, because previous versions of AGM stored the license in C:\Program Files (x86)\ESRI\License11.0
I recently spent some time authorizing licenses.
Ltod
Hi, we upgraded 2 weeks ago and everything is working fine.
Best,
Upgraded ArcGIS monitor successfully to 2025.0.1
Testing new functionalities:
ArcGIS online monitoring - failed getting an error - Invalid organization ID: undefined
Any insights on this issue? I have escalated with ESRI support.
Regards,
Antony
