ArcGIS Monitor 2024.1 Portal Item and Group Counts Wrong - too high
839
6
02-04-2025 11:22 AM
DavidColey
MVP Frequent Contributor
Hello - after registering 11.4 Portal with 2024.1 Monitor, my portal item counts are now showing 10,000 instead of 665.  My group count is showing 500, it should be 42.
DavidColey
I get it now.  If I go into portal admin and view the index status I see the high group and item counts.  Then when when I view the sharing directory from the Portal content directory I can then see all of the items and groups that are owned by esri_en, arcgis, etc etc. that come with portal.
It just threw me that the counts as reported by Monitor 2023.3.1 were so much lower....
MichaelVolz
Esteemed Contributor
Can you provide an example URL of the sharing directory from the Portal content directory (You can hide org specific portions of URL)?
DavidColey
Sure, well when I go into my Portal admin Index and view the index status, this is what shows:
Then the Portal component shows that I have
Users: 116
Groups: 529
Items: 10,000
The only count that the portal component has correct is my 116 users
So I thought when I saw the index counts so high in the Index Status I went to the Portal Content:
....gis05.ourorg.net:7443/arcgis/sharing/rest/community/groups?q=esri
and do a group search, in this case on "esri"
that comes back with 350 groups that have 'esri' somewhere in the group name or descript or summary or owner. If I do 'arcgis', I get an additional 260 groups.  So to me anyway it seems clear that the default is just showing totals of everything that comes into portal as a content type
ReeseFacendini_MadCo
I'm having the same issue, excapt I only have 55 items, and 5 groups. Not the 10,000 and 490 that Monitor is indicating. It's almost like Monitor is now reporting the upper limit of items / groups, instead of the actual number.
DerekLaw
Esri Esteemed Contributor
All,
Apologies for this issue. The Monitor team is working on a patch to resolve this. I will post an update when we have news to share. Thanks for your patience.
Hope this helps,
DerekLaw
All,
UPDATE: the ArcGIS Monitor 2024.1.1 patch that addresses this issue is scheduled for release on March 20.
Thanks for your continued patience,
