ArcGIS GeoEvent Add-on- Strictly for Stream Services Only?
981
02-12-2020 09:21 AM
Amanda__Huber
MVP Regular Contributor
Hey ArcGIS Monitor‌ Team,
We just had a quick question- is the GeoEvent Add-on strictly for stream services only or can it also be leveraged for other input/ service types?
Thanks!
by Anonymous User
Not applicable
The "ArcGIS GeoEvent Add-on" is designed only for ArcGIS Server GeoEvent stream services. If you have the  ArcGIS Server GeoEvent Extension (10.3 or higher version) already running with a streaming data feed, you can use the ArcGIS Monitor's ArcGIS GeoEvent extension to monitor the number of events at a sample interval. The ArcGIS Monitor extension will connect to the defined GeoEvent server and retrieve statistics about the
server and its related traffic.
by Anonymous User
Not applicable
SpatialAmolOne92
Hey @Anonymous User - Does this means that we cannot monitor ArcGIS GeoEvent using the extension unless we have stream services?
Looking forward to your insight.
Best,
Amol
