2023 cannot register ArcGIS Server
1108
04-21-2023 06:52 AM
MarkCederholmEvergy
In Monitor 2023, while I can register a Portal component just fine, I have not been able to register an ArcGIS Server component.  I get either "An error has occurred" or "Cannot read properties of undefined (reading 'map')."  Does it make a difference that I've been trying to register a federated server?
GeoJosh
Hi Mark,
Josh
GeoJosh
Hi Mark,
Josh
MarkCederholmEvergy
I've been connecting through the port using the Portal admin credentials.  I'll try some different combinations of connection vs. credentials as well.  There are also different server versions (10.6.1, 10.8.1, 10.9.1) that I can try.  I'll let you know how it goes.
MarkCederholmEvergy
That was my mistake, trying to use the Portal admin account.  Using the local admin worked.
