Excel Report for ArcGIS Monitor - DEPRECATED
8866
19
05-22-2023 07:00 PM
AndrewSakowicz
DEPRECATION ANNOUNCEMENT: There will be no updates for ArcGIS Monitor 2024.1 or newer.
2024.1 has several new features and components, see What’s New in ArcGIS Monitor 2024.1 that the old excel report would not support. Note, there are two significant improvements related to analysis. 1. Export/import of analysis views 2. New Table and Rich text elements in analysis views We hope those new features will empower users to build reports that address their specific needs (vs. getting all data as Excel report does) and will reduce/eliminate the need for this Excel report. ArcGIS Monitor teams welcomes your ideas. Please use https://community.esri.com/t5/arcgis-monitor-ideas/idb-p/arcgis-monitor-ideas
Get started
Excel Report for ArcGIS Monitor provides information about components, logs, metrics, and alerts.
To run using provided executable for windows, unzip ExcelReport.zip from
https://prof-services.maps.arcgis.com/home/item.html?id=248e22510a454e9c906204d3ad45adca
go to dist folder and execute from command line:
ExcelReport.exe -f sampleConfig.json
version: 20240927.0
Note, this utility is not an ArcGIS Monitor product supported feature or a supported Esri product.
Overview
  1. Components
    1. Overview table (e.g., see below host _components)
    2. logs for ArcGIS Portal and Server (e.g., see below arcgis_server_log)
  2. Metrics
    1. Statistics table for a selected metric name (e.g., see below host_CPU_Utilized)
    2. Top 10 components chart (there is no hyperlink.  It is assumed users will click the above statistics worksheet and navigate to the left worksheet)
    3. Alerts chart (there is no hyperlink.  It is assumed users will click the above statistics worksheet and navigate to the left worksheet)
  3. Key Performance Indicators
    1. highest alerting status
  4. Alerting components
Component overview
ArcGIS Server Log
Metric statistics
Top 10 components
Alerting components
19 Comments
Mark_Prettyman
Hi!  The link above, to download ExcelReport.zip, requires Esri credentials or an AGOL login...but my AGOL login only returns the "not a member of this organization" error.  Should I be using different credentials other than my AGOL login, or could the file be made public (like the recent ArcSOC Optimizer is)?  Thanks!
Tobias_Gerber
I have the same behaviour and cannot download the ExcelReport.zip. Please make the file public accessible like the recent new version of the ArcSOC Optimizer.
AndrewSakowicz
@Mark_Prettyman , @Tobias_Gerber .  Thank you, my mistake.  This is fixed.
ManojKumar4
Hey Andrew,
Can we get this functionality added to ArcGIS Monitor site page as it was at 10.8.1 ?
Manoj Kumar
JamesBratton
Is this supposed to have the same output as the Excel Report for Monitor 10.8?  I don't see as much information listed.  For instance, on the old version, there was a AGSServiceTr tab.  I don't see this on the current report.  There is a svcReqReceived tab, but it is mostly blank.
BHK
Hi
Thanks for this, and can you please let me know if there is a way that we can specify the output directory  to a Custom path and is there any way that we can automate this using Windows Task Scheduler? if Yes so how can I update the dates in "end_time" for always last 30 days instead of hard coding like
"year":2024, "month":3, "day":3, "hour":24
AndrewSakowicz
  1. output directory cannot be changed relative to the executable.  But you can move all folders to any directory.
  2. this is a command line tool and can be run through WTS as any other command line.
  3. Last 30 days example:
"end_time":  {"now": true,
            "year":2021, "month":10, "day":4, "hour":19} ,
        "past_days":30,
        "past_hours":0,
BHK
Thanks Andrew,
So if we have the option of "now": true, and  "past_days":30, or"past_days":15, and Do we still need to explicitly pass these options  "year":2021, "month":10, "day":4, "hour":19 ? what is the point of using them?
AndrewSakowicz
if  "now": true,  "year":2021, "month":10, "day":4, "hour":19 is ignored.
The below examples might help:
Last 30 days from now:
        "past_days":30,
        "past_hours":0,
last 30 days from "year":2021, "month":10, "day":4, "hour":19:
"end_time":  {"now": false,
        "past_days":30,
        "past_hours":0,
MKR
Is it possible to confirm a list of valid timezones for the excel report tool?
I am looking for BST (British Summer Time)
Thanks!
SteveMcCarthy
@AndrewSakowicz
Few Install/Configure questions:
  1. In the SampleConfig.json can the user be anyone with Admin access?
  2. Is this the exact Syntax to run the SampleConfig.json --
    ExcelReport.exe -f SampleConfig.json, e.g.?  I assume we remove the , e.g..
    I get this error when I leave it in:  C:\Users\smccarth\OneDrive - Williams\Desktop\ESRI\ArcGIS Monitor\Excel Report\ExcelReport\dist>ExcelReport.exe -f SampleConfig.json, e.g.
    usage: ExcelReport.exe [-h] -f FILE
    ExcelReport.exe: error: unrecognized arguments: e.g.
AndrewSakowicz
try to
1. in commend line, cd to the folder where you have ExcelReport, e.g. "C:\Users\smccarth\OneDrive - Williams\Desktop\ESRI\ArcGIS Monitor\Excel\Report\ExcelReport\dist"
 2. execute ExcelReport.exe" -f SampleConfig.json
But this should also work
"C:\Users\smccarth\OneDrive - Williams\Desktop\ESRI\ArcGIS Monitor\Excel\Report\ExcelReport\dist\ExcelReport.exe" -f SampleConfig.json
ChrisTaylor2
Hi @AndrewSakowicz
My Excel Report hasn't been running since I upgraded to Monitor 2024 last week. I'm on version 20240123.1, and get this error now when I try to run it:
09/16/2024 09:25:16 AM INFO: version:20240123.1
09/16/2024 09:25:16 AM INFO: Start
09/16/2024 09:25:16 AM INFO: Arguments: ExcelReport_config_Prod_1d.json
09/16/2024 09:25:23 AM ERROR: 'properties'
09/16/2024 09:25:23 AM ERROR: None
File "ExcelReport.py", line 14, in main
File "modules\report_builder.py", line 24, in __init__
File "modules\Wkb\wkb_builder.py", line 27, in __init__
File "modules\Wkb\wkb_builder.py", line 117, in _add_component_wks
File "modules\Wks_data\wks_host_specs.py", line 5, in __init__
File "modules\Wks_data\wks_host_specs.py", line 24, in _get_data
KeyError: 'properties'
Thanks for your help.
Chris
AndrewSakowicz
@ChrisTaylor2 , thanks for reporting.  The fixed is scheduled to be included in the 2024.1 patch.
AndrewSakowicz
@ChrisTaylor2 , FYI, I was able to address issue in Excel Report for ArcGIS Monitor 2024.0 is available on Excel Report for ArcGIS Monitor - Overview
cgekaputra
Hi @AndrewSakowicz
I have ArcGIS Monitor v. 2023.3.1. I'm facing an error when running json
TypeError: component_by_type() missing 2 required positional arguments: 'resultRecordCount' and 'resultOffset'
Could you help with that
Thank you,
René_Ténière
Hi @AndrewSakowicz
Any chance you will be able to release the Python version like you did for v2023? I had added the ability to change reporting location and added email functionality... I can also send you my code to incorporate if you prefer.
Marcelo_Cesar_AugustoTorres
Is there an upgrade to ArcGIS Monitor 2024.1?
I'm getting errors for the following components:
arcgis_portal, arcgis_server : IndexError: list index out of range
argis_data_store, dataset: KeyError : 'arcgis_data_store' (or 'dataset')
AndrewSakowicz
This is expected. The 2024.1 has several new features and components, see What’s New in ArcGIS Monitor 2024.1 that the old excel report would not support.  At this point, there are no timelines for upgrading this Excel report.
  • Export/import of analysis views
  • New Table and Rich text elements in analysis views
Contributors
