Excel Report for ArcGIS Monitor - DEPRECATED
7673
19
05-22-2023 07:00 PM
AndrewSakowicz
DEPRECATION ANNOUNCEMENT: There will be no updates for ArcGIS Monitor 2024.1 or newer.
2024.1 has several new features and components, see What’s New in ArcGIS Monitor 2024.1 that the old excel report would not support. Note, there are two significant improvements related to analysis. 1. Export/import of analysis views 2. New Table and Rich text elements in analysis views We hope those new features will empower users to build reports that address their specific needs (vs. getting all data as Excel report does) and will reduce/eliminate the need for this Excel report. ArcGIS Monitor teams welcomes your ideas. Please use https://community.esri.com/t5/arcgis-monitor-ideas/idb-p/arcgis-monitor-ideas
Get started
Excel Report for ArcGIS Monitor provides information about components, logs, metrics, and alerts.
To run using provided executable for windows, unzip ExcelReport.zip from
https://prof-services.maps.arcgis.com/home/item.html?id=248e22510a454e9c906204d3ad45adca
go to dist folder and execute from command line:
ExcelReport.exe -f sampleConfig.json
version: 20240927.0
Note, this utility is not an ArcGIS Monitor product supported feature or a supported Esri product.
Overview
  1. Components
    1. Overview table (e.g., see below host _components)
    2. logs for ArcGIS Portal and Server (e.g., see below arcgis_server_log)
  2. Metrics
    1. Statistics table for a selected metric name (e.g., see below host_CPU_Utilized)
    2. Top 10 components chart (there is no hyperlink.  It is assumed users will click the above statistics worksheet and navigate to the left worksheet)
    3. Alerts chart (there is no hyperlink.  It is assumed users will click the above statistics worksheet and navigate to the left worksheet)
  3. Key Performance Indicators
    1. highest alerting status
  4. Alerting components
Component overview
ArcGIS Server Log
Metric statistics
Top 10 components
Alerting components
19 Comments
Contributors
