Hello,
I´ve been working with Mission but I can´t make Mission Responder work correctly. I´m using Android devices, so I need more details about Mission Responder and android compatibilities.
Thanks!
Hi PG89,
Sorry to hear about your troubles. If you could provide us as much detail as you can about your environment (version, any system properties, use of web adaptor with Mission Server, any errors) that would be most helpful.
We are working on a 10.8.1 Portal version, using web adaptor and no errors appeared during mission installation. By now mission responder is not working correctly, and we made tests on two android devices Xiaomi and Galaxy Tab A7.
Thanks for your help
Hi PG89,
Thank you for reaching out. Could you start by telling me what version of Responder you are using? To find this information you can go to the settings page and tap "About Mission Responder." You should be able to see an app version on this screen. I would also like to know what problems you are having while trying to use Responder?
We are using Mission Responder 20.1.0 because new version is not compatible with our portal (10.8.1).
Problems are about display. Some devices stop working, goes blank, can receive geomessages but application starts to fail (Xiaomi). On Galaxy Tab device you can only sign up and then application goes to blank, is not possible to see the map or explore the application. So i´d like to have more specification about compatibilities (android versions, etc)
Regards
Thank you for the feedback. For the 10.8.1 enterprise version you will need the 20.2 version of Mission Responder. You can find version 20.2 on the Esri Downloads page. The listing for Mission Responder is under the ArcGIS Server section. The steps needed to download the version on your device are below:
Thank you again for reaching out to us and please let us know if these steps worked for you or if you have any other questions or issues.
Thanks for your help.
We made some tests and in the devices that i mention before the problem is solved, but now on Samsung Galaxy A11did not work. The app closes right before log in. Is there any devices recommendation?
Though our product should work on most google and android devices, we have tested and verified that Responder works on Google Pixels and Samsung Galaxy S series devices. Thank you for verifying that the above solution worked.
Any recommendation about devices ( brand, android version, etc) ?
Our customer is going to use Galaxy A 11
