Viewing an ENC layer (.000; S-57)
591
10-07-2024 01:44 AM
Lieke1006
Hi all,
I'm having trouble viewing an ENC layer (.000 extension, S-57 file). I can add the data, it pops up in the contents, but there is nothing visible (it also does not show any sublayers). Also, I cannot see it on the map. I checked licensing, I have the maritime license, my ArcGIS Pro software is up to date and the file opens correctly in QGIS so it isn't corrupted or empty. In the symbology tab everty viewing options is checked and the spatial extent of the layer is read in correctly (WGS1984). If I go to properties, I can see that 'extent' is empty as well. How can this be solved?
pocalipse
Hi
ENC layer supports SCAMIN so you probably have to zoom in to see data. I think you may click the zoom to make visible button in the content menu of the layer.
