SCAMIN population in ArcPro 3.1
675
03-09-2023 06:50 PM
CBBiong
New Contributor III
I'm not sure if I'm the only one experiencing this but when I try to export my GDB to an S-57 file, the resulting file does not have the SCAMIN values. Can anyone confirm if this is an issue with Pro 3.1?
CBBiong
New Contributor III
This has been resolved in version3.1.2.
Paulakark
Hello @CBBiong ,
I can confirm that there is an issue with the SCAMIN calculation based on the configuration file. A workaround right now is to specify the SCAMIN step/fixed value on the features in the NIS.
Once you populate the SCAMIN attribute, SCAMIN will be calculated.
For guidance on specifying the SCAMIN value, refer to this help topic: https://pro.arcgis.com/en/pro-app/latest/help/production/maritime/override-scamin.htm
Thank you,
Paulina
CBBiong
New Contributor III
Thanks for the confirmation. I'll be using another software for SCAMIN population for the mean time. Hope this gets fixed in the next patch. Thanks!
CBBiong
New Contributor III
