State Plane and WGS84
1183
08-06-2025 01:01 PM
digtlpete
I've modeled a 12-mile-long LRT corridor using data in the State Plane coordinate system. However, when importing the data into UE5 with the ArcGIS SDK, it doesn't align correctly. I've tried setting the WKID to the appropriate State Plane projection, but it doesn't seem to have any effect.
I encountered a similar issue when working with Cesium and Google 3D Tiles.
Any thoughts or suggestions would be greatly appreciated.
Brian
MichaelBranscomb
Esri Frequent Contributor
Can you share more info about the data formats / layer types you're using for the LRT corridor and the other layer it's not aligning with? And is it not aligning horizontally or vertically?
Thanks
