Teleport Area in Unity for the Quest 2
4074
16
09-06-2022 12:29 AM
WH1981
I have a question. I can turn my head in the Oculus Quest 2 and i can look around the city. I can also Continous move over the Basemap with the dumpstick of the controller but now i trying to make a teleport area on the basemap or the roads layer so that i can jump to locations ((continous move is slow:)). I have set a teleport provider on the XR Origin and often you can add the teleport area component at a gameobject that has a collider with the result you can jump on it. But the Basemap and Road layer are game objects?
Can someone help me with this?
WH1981
Thanks! Sorry i am very new with this. Only why must i add a tag on a gameobject (reticle?) when i already have a script that add tags? And runs the scenecomponent provider script on a automatic way? I try to understand the logic of the tags and scripts.
WH1981
On which gameobject must i add the tag in the unity editor?
IngmarWittmann
You just have to add the Tag to the List. Via the line "gameobect.tag = "ArcGis";" in the SceneComponentProvider all Arcgis gameobjects get tagged. You can name the Tag what ever you want, i named it ArcGis.
WH1981
Hello Ingmar,
Sorry but i can't find the script SceneComponentProvider. In which folder of ArcGIS Maps SDK for Unity?
IngmarWittmann
WH1981
Thanks it works!
Only one thing. When i add a custom reticle to the line visual i didn't see them. Most of the time i add this to the teleportert area component and then it works but thats now through the script.
IngmarWittmann
Custom reticle in the line visual component shouldnt be a problem, the transform position and rotation  should be zero, no collider and not to small.
