Moving a rigidbody in the ArcGIS Enviroment
1003
11-24-2022 08:30 AM
ChristofferLindellBolin
Hi, I an currently trying to move an entity with a rigidbody in the ArcGIS enviroment, but have been unable to do so. I want to be able to move an entity between an ArcGIS point A and ArcGIS point B with a rigidbody. How would I achieve this?
ReintJ
I solved this with the following steps:
- Remove the rebase component from your ArcGISCamera (only recommended for small local scenes though).
- Add a empty gameobject with an ArcGISLocation component, this object is the parent of all your physics related stuff.
- Put all your Rigidbodies as childs of this object, without the ArcGISLocation component so the transform can be used normally for the physics system.
I hope this helps.
I didn't find a solution with using the rebase component, since the physics system doesn't update according to the world movements. But I guess you can lerp the position (be it the transform, HPTransform or cooridantes) between the positions of A and B.
ReintJ
I hope this helps.
Great, thanks. I have just been able to get it to work when I removed the Rebase component, took me a while to figure that out.
Ideally for future releases of the plugin, it would be a big bonus though if they could include support for or create an alternative to Rigidbody for the global scene with the ArcGIS rebase component.
