Updated on Feb 2021:
ArcGIS Maps for Adobe Creative Cloud 2.2.1 patch is now for Windows users only. macOS users should get the version 2.2.2 update here which contains all the fixes included below and a fix for the compatibility issues with opening .aix files from ArcGIS Pro on a macOS with Adobe Illustrator v25.1 and above.
Download the 2.2.1 patch (Windows) from here or get the latest update directly from the extension.
This patch addresses the following issues when importing AIX:
- Incorrect shape for polygons rendered in ArcGIS Pro as gradient, pattern, or hatch fill (ENH-000133904)
- Missing masks for layer defined in ArcGIS Pro with annotation
- Vector tile layer import anomalies for AIX created from ArcGIS Pro 2.7
- Missing Esri logo and copyright information when syncing new data in the AIX workflow.
- Invalid file error when opening AIX created from apps other than ArcGIS Pro
For more information about the product, please visit help.
Please continue the conversations on our forums or contact Esri Technical Support if you encounter any issues. You can also post ideas on the ArcGIS Ideas site. ArcGIS Ideas is a good way for you to get involved in making our application better.
Thank you.
Maps for Adobe CC team
