unable to add excel data in ArcMap 10.3
2201
11-15-2016 11:40 AM
DanielZura
I'm using ArcMap 10.3, and I'm trying to add a table from excel. In the Add data dialog box, I am not able to navigate to any files from my computer, and in the "show of type" drop down menu, it seems to only allow "Datatsets, Layers and Results." Any ideas? I'm really new on this so maybe it's something obvious, but can't figure it out.
Thanks!
DanPatterson_Retired
have you tried Excel To Table—Help | ArcGIS for Desktop in the interim?  Does it work?
DanielZura
Thanks for the tip. I don't know how to make that work though... how do I create or specify an output table? Does that code go into the python window?
DanielZura
ah! okay. I found the excel to table tool. it seems to have imported, now I just need to find it. Thank you Dan!
Since it is a table, make sure that you have the 'data view' icon selected in the table of contents, since it won't show up in 'layer view'
Using the table of contents—Help | ArcGIS for Desktop
