S-57 and C-MAP reader for ArcGIS Pro
216
02-22-2021 02:37 AM
GiorgioForti
I have two questions to ask :
1) is an s-57 reader planned in the ArcGIS Pro roadmap ?
2) Is there a C-MAP plug-in for ArcGIS Pro?
Thanks in advance for response
DanPatterson
MVP Notable Contributor
ArcGIS Pro Roadmap - January 2021 - GeoNet, The Esri Community
Nothing specific... but maybe @KoryKramer has a more detailed list
... sort of retired...
KoryKramer
Community Moderator
Support for S-57 is in the product plan, though not immediately in the next release (2.8).  See https://community.esri.com/t5/arcgis-pro-ideas/enc-s-57/idi-p/968679 up vote/follow for updates.
As for the question about C-Map, is that referring to https://commercialmarine.c-map.com/en/route-planning-and-fleet-management/c-map-fleetmanager ?  Maybe somebody in the https://community.esri.com/t5/arcgis-maritime/ct-p/arcgis-maritime place has more insight, but whether/when they develop a solution for ArcGIS Pro may be a better for C-Map directly.
TomDePuyt
Hi Giorgio,
I hope you are doing well.
In the past, C-MAP only provided their propriety C-98 formatted ENC datasets that required a plugin for ArcMap.  Now we have ArcGIS Maritime Server Extension (Maritime Chart Service MCS) customers using C-MAP data.  MCS only supports standard S-57/S-63 datasets, so C-MAP must be providing that option now.   If your customer requires the use of S-63 encrypted datasets, they will still be required to use MCS to publish map services and bring those into ArcGIS Pro.
gforti
Thanks Tom and Kory
