Hello everyone, i've been working with the Nautical Symbology toolbar. I want to use the toolbar to apply S-52 View to my map. But the problem is i can't see the S-52 View option in the View combo box. Can anyone please help me out with this. Many thanks!
There is a number of links which can be found using 'nautical' as a keyword search, did you see any of these?
https://community.esri.com/message/589399#comment-589399
Nautical symbology—Help | ArcGIS for Desktop
Views are map settings that can be saved to and retrieved from any geodatabase. They allow you to manage the properties of a data frame and layers so they can be reapplied at any time while allowing you to decide which current map properties to keep and which to override.
Thanks Dan, I did followed up all these instruction but still can't see the S-52 View option
So I wonder if I had set up the Product Library wrong way. In the Layer Properties (ex: AidsToNavigationP) > Symbology, is this normal if it don't have the S52 representation symbols? Thank you
