How do I transform the geographic coordinate system?
220
06-22-2020 11:49 AM
RickCheney
Occasional Contributor II
My map has various data sources. Sometimes I get the following error:
"This coordinate system has a geographic coordinate system that differs from one or more data sources in the map.
Use the Transformations button to set or change these transformations"
For example, when I view the properties for the Data Frame, I get the error.  I understand that I can use the Transformation tool as shown in the attached image, but I'm not sure which settings to select.  I don't understand how to use the tool in general.
Any guidance or advice you can offer is greatly appreciated.
Reply
DanPatterson
MVP Frequent Contributor
Rick Cheney
Geographic datum transformations—Properties of maps | Documentation
There is a Note in there that not all geographic transformations are installed and if one isn't offered, you can download it
Other links
Geographic Transformations (Environment setting)—Geoprocessing | Documentation
And if you want to get everything into a common coordinate system, then use the Project tool and provide the transformation there
... sort of retired...
RickCheney
Thank you very much Dan!  I will look through the information at the links you provided.  I do want to get everything into a common coordinate system and the Project tool sounds like the way to do it.
I am not familiar with the Project tool.  I tried searching ArcMap but I didn't find anything.  Where do I find the Project tool?
Also, I'm not 100% sure which coordinate system to use but I think I should use NAD83(CSRS98) ??  Is that correct, the map is for the area along the border of Minnesota and Ontario, Canada
Reply
DanPatterson
I don't use arcmap any more, but if memory serves
Arctoolbox, Data Management tools, Projections and Transformations, Project
The NAD83 thing with CSRS98 rings a bell, but as long as they are in the same one
RickCheney
Sorry for the delay in responding.  I will need a few days to study the information at the links provided. I'm still trying to figure out which projection (or whatever) to use. I will reply back with either more questions or to mark as answered.  Thanks again.
Reply
