Exporting to PDF after exporting by clipping graphics
66
10-28-2019 06:33 AM
I have a MXD where I first exported the map to a JPEG and clipped the output to the graphics extent. I then tried to export it as a PDF, and now it clips the image in the PDF to the just show the graphics like the JPEG and not show the title or anything I've recently added to the map. When exporting to PDF, I did not check the box to clip output to graphics extent so I'm not sure if it's just clipped for eternity after you do it once? I also tried it with checking the box to see if anything would change, it didn't.
Tags (1)
Reply
I realized I had sent my title to the back via "Order" and had to bring it forward. Then it showed up. It looked like it was on top because the map's data frame was transparent.
Reply
Reply
