Best option for interpolating hot and cold zones in river systems
848
12-08-2016 11:08 AM
JosephLafontaine
Hello,
I am currently troubleshooting through some issues of trying to create hot zones or cold zones based on measured levels at multiple data points within a river system. The goal is to create zones of higher and lower values that can be identified within the river. I have tried using the Getis-Ord hotspot analysis technique using both a fixed distance and inverse distance methods but have found narrowness of the system allows too much interference across channel boundaries and across island barriers. Additionally I have tried the Geostatistical wizard ordinary kriging but again it does not take into account that points on one side of a island can not influence points on another side of an island due to flow direction of a river. Attached a photo of this
I have found that it is extremely difficult to work with interpolation methods and hotspot analysis in a more linear system. I do have the river system boundarys and the river system as raster data for depth, velocity vectors, etc if that helps? Does anyone have any recommendations for possibly making this task easier or a better approach that I am able to validate the results of?
SteveLynch
JosephLafontaine
Hi Steve,
I have explored this method but It gave me quite weird results as I think I may have been doing it improperly. I had set the barrier layer to the river polygon I have currently which represents the inside of the river as the polygon or everything that would be water. Would I need to create an inverse of this layer to actually have a representative layer of all land values? If so im wondering how I would go about doing this
SteveLynch
Joseph
Your boundary polygon would be the river (the blue area in your image). It means that the interpolation will be constrained by this boundary.
Please post the output image that you get and tell us why you think that it is weird.
Also, what is it that you are interpolating?
-Steve
