Hi Team,
"there is functionality built into those tools that should be handling the annotation transformation based on the scale differences between the reference scale of the annotation feature class and that set on the Data Frame and subsequent (Product Library) Instance. There is also an Update Annotation tool which will refresh the current annotation against its source feature class and any label expressions you may also have configured. " Yes, it is the case as you mentioned.
Aviation products works properly, update annotation tool makes necessary changes but I'd like to share a detail or maybe a bug or maybe as a team you designed to work this tool like that way is; tool looks when a different scale is being used for charting, it seems it just searches the size value on the script at visual specifications rules, scales the values up to new scale. Up to this point everything is fine.
But if you have values like LIN or Horizontal or vertical offset which are the important parameters for the annotation design and the parameters of the element placement, these values are not updated up to new scale so you lost the annotation design. Maybe usage of the system can be change or when creating a new annotation feature class we need to use it out of scale or must be a way to make it dynamic up to scale.
Any help would be useful for the subject.
Thanks.
