ArcGIS 10.5 Euclidean Distance-Ouputraster with wrong values
3137
10
02-15-2018 08:48 AM
TobiasSchulz
The output of my Euclidean distance from Roads seems to show the calculations only until the last feature ot the bottom. The process extend goes on though, but shows wrong values. It should get brighter instead of being dark (like on the other sides)
With dark beeing close to roads and bright further away.
What did I do wrong/ Do i have to do to get raster values to the full extend of the processing extend?
Note:I got this feature (mainroads) by deleting some other features (sideroads) from the original feature (main and side roads). The above mentioned problem does not occur with the original feature.
XanderBakker
Esri Esteemed Contributor
Definitely something went wrong with the extent. That's why I think the OP should mark your answer as the correct one (I'm not a moderator of this space so I can't do that).
I included my previous comment to indicate that it is not necessary to convert the roads to raster to correctly do the distance calculation. It was also to indicate that it would be good to use "better" values for the extent.
