Can the service be used with an external system?
2270
06-16-2022 07:21 AM
UngvárszkyBalázs
Hi!
Our team would like to test an ADAS system’s performance, by using this service as a route calculator. Is there any option, to extract the turn-by-turn navigation’s output to an external system? In Esri Leafle? or in any other ARCgis API?
So the goal would be for routing messages to not/not just appear on a display, but to be also received in some form by an external system, for example via CAN messages or ethernet packets, or any other way. And if yes, then in what format and with what capabilites?
On the other hand, in what specific hardware and environment can this routing API work?
Thanks in advance!
JillianStanford
Leaflet is a client API, it is used to request data from the ArcGIS Platform services and display it to the end user. It's one of many clients - https://developers.arcgis.com/documentation/mapping-apis-and-services/apis-and-sdks/#web-apis. You can also use a non-Esri client as long as it can communicate with REST endpoint services.
The services https://developers.arcgis.com/documentation/mapping-apis-and-services/services/ communicate with the client to provide access to the data and operations such as routing.
JillianStanford
Have you looked at ArcGIS Platform? - https://developers.arcgis.com/documentation/mapping-apis-and-services/arcgis-platform/
You can consume individual REST endpoints for just the services you want. Here are are the output formats - https://developers.arcgis.com/rest/services-reference/enterprise/output-formats.htm
Jill
John-Foster
You can try the routing service REST API, it is fully documented here https://developers.arcgis.com/documentation/mapping-apis-and-services/routing/services/routing-servi...
--jf
UngvárszkyBalázs
Thank you, and maybe I missed something, but these output types and behaviour are also true for the Esri Leaflet platfrom? So is it's considered as an ArcGIS Platform as well?
I'm asking, because it's seems like a different platfrom and I'm not sure if they are also true for Esri Leaflet too.
JillianStanford
UngvárszkyBalázs
Thank you for your answers! You helped us a lot!
