I downloaded the World Temperature Change 2050 Scenario 2.6 from the Living Atlas to create a web map. The map's layer looks like this:
instead of showing degrees Celsius. When I used the classify the image display option, the whole image just goes all black and even if I try to make it go back to how it was before, it doesn't do anything.
Any help will be greatly appreciated!
Isabel
Hi Isabel,
There’s good news and bad news for this one:
Bad news: we will be retiring these layers soon, so there’s no planned bug fix for them.
Good news:
Cheers,
Dan
Here is the url for this Living Atlas layer:
https://landscape6.arcgis.com/arcgis/rest/services/World_Temp_Chng_2050_26/ImageServer
Hi Isabel,
Good news:
Cheers,
Dan
Hi Dan!
Thank you very much your answer, I actually was able to do just that, and work the layers in ArcGIS pro before uploading them as web layers. It worked just fine.
I really appreciate you sent those links because, now that I see them, I think I will change them to the layers to the CMIP5 climate model outputs you are creating.
Thank you thank you!
Isabel
