Hi Robert,
In 2018 I reached out to FEMA for advice on symbology. They sent me two MXDs they used to symbolize the layer for their own services. In that, they used combinations from two categories in the FEMA flood zones to create a symbol: FLD_ZONE and ZONE_SUBTY. Some of the combinations seemed contraintuitive so I reconfirmed with them, and the result is what you see in the feature and image layers in the Living Atlas.
Every year, sometimes twice a year, a script is run against the FEMA flood layer update to assign the esri_symbology field from these fields: FLD_ZONE, ZONE_SUBTY. Then the layer is updated with that.
You found some of the more unusual combinations which led to symbols receiving a 0.2% flood hazard color, it seemed strange to me too but I got confirmation from the agency August 1, 2018.
The symbols they recommended seemed more about people understanding the layer more than simply assigning a color to a code, so the symbology was well received as a "front end" to the dataset.
Every polygon is put through the following decision tree to determine its esri_symbology value (row[2]). The result is an integer between 0 and 15 and that value is also rasterized to create the image layer:
print("Cursoring through copy of FEMA feature class and populating esri_symbology...")
with arcpy.da.UpdateCursor(incodedfema,["FLD_ZONE","ZONE_SUBTY","esri_symbology"]) as cursor:
for row in cursor:
if row[0] == "A":
if row[1] == 'ADMINISTRATIVE FLOODWAY':
row[2] = 2 #Regulatory Floodway
else:
row[2] = 1 #1% Annual Chance Flood Hazard
elif row[0] == "A99":
if row[1] == "AREA WITH REDUCED FLOOD RISK DUE TO LEVEE":
row[2] = 7 #Area with Reduced Risk Due to Levee
else:
elif row[0] == "AE":
if row[1] == 'AREA OF SPECIAL CONSIDERATION':
row[2] = 3 ##Special Floodway
elif row[1] == 'COLORADO RIVER FLOODWAY':
elif row[1] == "FLOODWAY CONTAINED IN STRUCTURE":
elif row[1] == "STATE ENCROACHMENT AREA":
elif row[1] == "FLOODWAY":
elif row[1] == "1 PCT CONTAINED IN STRUCTURE, COMMUNITY ENCROACHMENT":
elif row[1] == "1 PCT CONTAINED IN STRUCTURE, FLOODWAY":
elif row[1] == "FLOODWAY CONTAINED IN CHANNEL":
elif row[1] == "COMMUNITY ENCROACHMENT AREA":
elif row[1] == "COMMUNITY ENCROACHMENT":
elif row[1] == "ADMINISTRATIVE FLOODWAY":
else:
elif row[0] == "AH":
if row[1] == 'FLOODWAY':
else:
elif row[0] == "AO":
else:
elif row[0] == "AREA NOT INCLUDED":
row[2] = 15 #nodata
elif row[0] == "D":
row[2] = 4 #Area of Undetermined Flood Hazard
elif row[0] == "NP":
row[2] = 15 #nodata
elif row[0] == "OPEN WATER":
row[2] = 15 #nodata
elif row[0] == "V":
else:
elif row[0] == "VE":
else:
elif row[0] == "X":
elif row[1] == "1 PCT FUTURE CONDITIONS":
row[2] = 6 #Future Conditions 1% Annual Chance Flood Hazard
elif row[1] == "1 PCT FUTURE CONDITIONS, FLOODWAY":
elif row[1] == "1 PCT FUTURE CONDITIONS, COMMUNITY ENCROACHMENT":
elif row[1] == "1 PCT FUTURE CONDITIONS CONTAINED IN STRUCTURE":
elif row[1] == "1 PCT FUTURE IN STRUCTURE, COMMUNITY ENCROACHMENT":
elif row[1] == "1 PCT FUTURE IN STRUCTURE, FLOODWAY":
elif row[1] == "0.2 PCT ANNUAL CHANCE FLOOD HAZARD":
row[2] = 5 #0.2% Annual Chance Flood Hazard
elif row[1] == "0.2 PCT ANNUAL CHANCE FLOOD HAZARD CONTAINED IN CHANNEL":
elif row[1] == "0.2 PCT ANNUAL CHANCE FLOOD HAZARD CONTAINED IN STRUCTURE":
elif row[1] == "1 PCT DEPTH LESS THAN 1 FOOT":
elif row[1] == "1 PCT DRAINAGE AREA LESS THAN 1 SQUARE MILE":
elif row[1] == "AREA OF SPECIAL CONSIDERATION":
elif row[1] == "0.2 PCT ANNUAL CHANCE FLOOD HAZARD IN COASTAL ZONE":
elif row[1] == "0.2 PCT ANNUAL CHANCE FLOOD HAZARD IN COMBINED RIVERINE AND COASTAL ZONE":
else:
row[2] = 8 #AREA OF MINIMAL FLOOD HAZARD
else:
row[2] = 15
print("missing category in dataset, please check the logic in the script")
cursor.updateRow(row)
