Failure to add data from some (but not all) Living Atlas layers
2003
5
05-11-2021 12:46 AM
Jane_T
Hello everyone,
I am having trouble adding certain layers from the Living Atlas portal to ArcGIS Pro 2.5. For example, when I attempt to add the Terrain: Multi-Directional Hillshade layer I get the attached error (see screenshot). A number of other layers give the same issue. However, I am able to add certain Living Atlas layers without any problems.
I know I could just try use a layer that adds without issues, but my team has been using a map template which uses the Terrain: Multi-Directional Hillshade layer, so for consistency I want to be able to use this layer on my computer too. My colleague also has no trouble adding the exact same Terrain: Multi-Directional Hillshade layer which won't add for me.
Thanks in advance for any help.
JayantaPoddar
Are you logged in to ArcGIS Online (from Pro) using an organizational account?
Terrain: Multi-Directional Hillshade and many other layers are subscriber content.
What is subscriber content?
Subscriber content is the collection of ready-to-use map layers, analytic tools, and services published by Esri that requires an organizational subscription account to access. This includes layers from Esri such as NAIP imagery, landscape analysis layers, and historical maps. Subscriber content is provided as part of your organizational subscription and does not consume any credits.
You cannot access subscriber content using Esri public account. In case you don't have an organizational account, you can get a free trial or purchase ArcGIS for Personal Use license (non-commercial purpose) to explore subscriber content.
Think Location
DanPatterson
your screenshot?
... sort of retired...
Jane_T
Sorry it's there now. Not sure what happened the first time around.
JayantaPoddar
Think Location
Jane_T
This is the issue. I wasn't aware that some of the Living Atlas content was subscriber only.
RajinderNagi
We do have a tiled (cached) version of Terrain: Multi-Directional Hillshade layer, which is public and doesn't require login. It's called ' World Hillshade' and can be found here: https://www.arcgis.com/home/item.html?id=1b243539f4514b6ba35e7d995890db1d
Anyone lookin to use Multi-Directional Hillshade as basemap should use 'World Hillshade'.
