Error in date, time on the chart
440
04-19-2024 01:05 AM
Aissulunull
New Contributor II
Can you fix the error in the graph, the overlap of time, date on each other?
BernSzukalski
Esri Frequent Contributor
I would highly recommend to not use that application. It's still active, but has been replaced by the new Landsat Explorer:
https://www.arcgis.com/home/item.html?id=7a30da7ae1ee44248e12e99c928c4939
https://livingatlas.arcgis.com/landsatexplorer/#mapCenter=-11.398%2C21.124%2C12.000&mode=dynamic&mai...
There are a number of blog articles you will find that cover it's use:
https://www.esri.com/arcgis-blog/?s=#landsat%20explorer
BernSzukalski
You will have to give me some more information. I do not understand from your brief description what the issue is, and I can't tell what app you are using. If you can provide me additional repro steps I will look into things for you, but at this point I don't have a clue how to repro your issue or even what app you are using. Thanks.
Aissulunull
New Contributor II
Aissulunull
New Contributor II
When drawing up a graph (the NDMI moisture index or the NDVI vegetation index) in chronological order at the bottom, the date of the satellite images is not correct, since the date signatures overlap each other.
BernSzukalski
Aissulunull
New Contributor II
Thank you very much!
