Can you fix the error in the graph, the overlap of time, date on each other?
I would highly recommend to not use that application. It's still active, but has been replaced by the new Landsat Explorer:
https://www.arcgis.com/home/item.html?id=7a30da7ae1ee44248e12e99c928c4939
There are a number of blog articles you will find that cover it's use:
https://www.esri.com/arcgis-blog/?s=#landsat%20explorer
You will have to give me some more information. I do not understand from your brief description what the issue is, and I can't tell what app you are using. If you can provide me additional repro steps I will look into things for you, but at this point I don't have a clue how to repro your issue or even what app you are using. Thanks.
Hello. I used the app https://livingatlas2.arcgis.com/landsatviewer/
When drawing up a graph (the NDMI moisture index or the NDVI vegetation index) in chronological order at the bottom, the date of the satellite images is not correct, since the date signatures overlap each other.
Thank you very much!
