Drainage lines precomputed by Esri
1229
6
05-21-2020 08:58 AM
RobertoRossi
The ArcGIS Online Create Watersheds tool, permits to extract water catchment areas for points as input layer, based on
drainage lines precomputed by Esri
Are these drainage lines available in any format?
I just found Esri Hydro Reference Overlay, but it's a very small scale data, and I don't think it's the data the watershed tool is based on.
Thank you
Roberto Rossi
Padua University
CaitlinScopel
Hi Roberto, thanks for your question. The drainage lines that we used for the Create Watersheds tool are the National Hydrography Dataset Medium Resolution lines from USGS. We do not have these lines available anywhere as a downloadable service, so your best bet would be do go to NHD Plus - NHDPlusV2 Data and download the region you are interested in. Please feel free to email me directly if you have any other questions about the Create Watersheds tool. - cscopel@esri.com
Caitlin Scopel
CaitlinScopel
Caitlin Scopel
RobertoRossi
Thank you Caitlin for your kind and quick answer.
I used the ArcGIS Online Create Watersheds tool in Italy, so I imagine there should be global (worldwide) dataset, in addition to the US one (NHDPlus) you showed me. The page you link pointed to couple of links:
National Data
Global Data
but the second one contained just US data (the raster where regarding the great lakes area).
Furthermore, since the tool works online, I imagined there should also be a raster Online service (flow direction) working beneath.
Thank you
Roberto Rossi
CaitlinScopel
Hi Roberto,
I apologize for my small-mindedness. We used the HydroSHEDS data for areas outside of the US. Here is the website where you can find information on the data: USGS HydroSHEDS  and here is the download site USGS HydroSHEDS .
Sincerely,
Caitlin
ZhanerkeSharapkhanova
Hello, Caitlin Scopel. I have a question, in the description of this tool #Create watersheds (/external-link.jspa?url=https%3A%2F%2Fdoc.arcgis.com%2Fru%2Farcgis-online%2Fanalyze%2Fcreate-watersh...) it is written that the DEM 90m HydroSHEDS for the whole world is between latitudes 60 N and 56 S. My territory is in the indicated latitude. But I get the following error. Help me please
CaitlinScopel
Hi, could you email me directly at cscopel@esri.com and send me the point you are trying to delineate from? I will be able to look at where your point lands in relation to the files we have and figure out what the issue is. Please put your point in a file gdb and zip and then email to me.
Caitlin
RobertoRossi
Hi Caitlin Scopel‌,
I took a look to the HydroSHEDS data (the old USGS website doesn't work anymore, I found some information here: https://hydrosheds.org/page/availability )
The required data to extract water catchment are available for download (Drainage directions and DEMs with 3 sec, 15 sec, 30 sec resolution; Flow accumulation with 15 sec, 30 sec) as raster data (ESRI GRID format and BIL format).
My question is: are these data available also as Web layer (i.e. tile layer) in Living Atlas or anywhere? They should be somewhere online if the Create Watersheds geoprocessing tool works processing these data.
My goal is to load on AGOL the flow accumulation in order to be able to identify correctly the outlet.
Roberto
