Sea surface temperature is a key measurement for weather and climate prediction, ocean forecasts, tropical cyclone forecasts, and many coastal applications.
The Sea Surface Temperature layer in the Living Atlas is multidimensional, containing information about temperature across time. It provides global daily sea surface temperature measurements between 1981 and May 22, 2023.
Learn how the Sea Surface Temperature layer in ArcGIS Living Atlas can help you analyze and summarize sea surface temperature changes to gain insight into trends and patterns over time. For more information, see Warmest ocean ever.
