Updated from 4.28.10 to 4.29.7 and sketch and coordinate conversion widget no longer working
717
03-14-2024 01:16 AM
Flookfinders
I have just update to the latest version (4.29.7) from 4.28.10 and now when I display my map in my React application I get the following error:
Uncaught TypeError: Cannot read properties of undefined (reading 'length')
at get state (SelectionToolbarViewModel.js:5:1)
at f (tracking.js:5:1)
at o.getComputed (Property.js:5:1)
at p.state (subclass.js:5:1)
at p._renderRectangleTool (SelectionToolbar.js:5:1)
at p._renderDefaultTools (SelectionToolbar.js:5:1)
at p.render (SelectionToolbar.js:5:1)
at o (Widget.js:5:1)
at M.render (Widget.js:5:1)
at p._renderSelectionToolbar (Sketch.js:5:1)
And then I can no longer display the sketch widget and the coordinate conversion widget no longer displays the current coordinates of the cursor. Both were working fine in 4.28.10
ReneRubalcava
Esri Frequent Contributor
If you can provide a repro sample in stackblitz or github, would have a better idea, but not able to repro this issue in samples.
