I am currently pulling in a map service as a MapImageLayer. I'm using the IdentifyTask to display results in a popup; however, I'm having a few issues:
Relevant code snippets:
mapView = new MapView({
    container: app.containerMap,
    map: map,
    center: app.center,
    zoom: 9,
    padding: app.viewPadding,
    popup: {
       highlightEnabled: true,
       featureNavigationEnabled : true
var tLayer= new MapImageLayer({
    url: "https://server/arcgis/rest/services/tViewerr/tLayers/MapServer"
 map.add(tLayer)
mapView.on("click", executeIdentifyTask);
 function executeIdentifyTask(event){
   identifyURL = tLayer.url;
    identifyTask = new IdentifyTask(identifyURL);
    identifyParams = new IdentifyParameters();
    var identifyActions = [];
   identifyParams.tolerance = 15;
   identifyParams.returnGeometry = true;
    identifyParams.layerIds =    [2,3,4,5,6];
   identifyParams.geometry = event.mapPoint;
    identifyParams.mapExtent = mapView.extent;
    identifyTask.execute(identifyParams).then(function(response){
       var results = response.results;
      return results.map(function(result){
          var feature = result.feature;
          identifyActions = createIdentifyActions(result);
          var layerName = result.layerName;
          feature.popupTemplate = {
             title: layerName,
             content: "{*}",
             overwriteActions: true,
            actions: identifyActions
       return feature;
 }).then(showPopup);
function showPopup(response){
    if (response.length > 0) {
      mapView.popup.open({
          features: response,
      mapView.popup.on("trigger-action", triggerPopupActions)
Thank you!
Hi there, I was wondering if there was any update on this. I too have noticed the hamburger disappear. Bug or no longer supported?
Hey, any issues to fix this yet do we know? I'm pulling in a popup for a raster, from a layer hosted in the Atlas (URL), same issue occurring, pop up only shows when zoomed right in
