<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>DVRPC - U.S. Census Data Profiles</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } body{ background-color:white; overflow:hidden; font-family: "Trebuchet MS"; } #header{ height:40px; width:100%; background-color:#0077ac; } h1{ color: White; font-size:120%; margin:0px 0px 0px 20px; float:left; width:360px; } .roundedCorners{ -moz-border-radius: 4px; } .shadow{ /*slight shadow effect added for browsers that support this functionality*/ -o-border-radius: 10px; -moz-border-radius: 10px; -webkit-border-radius: 10px; box-shadow: 4px 4px 8px #adadad; -webkit-box-shadow: 4px 4px 8px #adadad; -moz-box-shadow: 4px 4px 8px #adadad; -o-box-shadow: 4px 4px 8px #adadad; } #subheader { font-size:small; padding-left: 40px; color: peru; } #rightPane{ background-color:white; color:peru; margin:5px; border: solid 2px cornflowerblue; } #mapArea, #map { background-color:white; border:solid 2px cornflowerblue; margin:5px; } #footer { border: solid 1px #7EABCD; background-color:white;color:peru;font-size:10pt; text-align:center; height:40px; } </style> <script type="text/javascript">var dojoConfig = {parseOnLoad: true};</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5compact"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.2/jquery-ui.min.js"></script> <script type="text/javascript"> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("esri.dijit.Popup"); dojo.require("dojo.number"); dojo.require("dijit.form.Button"); dojo.require("dijit.form.Textarea"); dojo.require("dijit.TitlePane"); dojo.require("esri.layers.FeatureLayer"); var map; var initExtent; var census3, census4; function zoomExtent() { map.setExtent(initExtent); } function init() { initExtent = new esri.geometry.Extent({ "xmin": -8502778.91, "ymin": 4784652.06, "xmax": -8227605.61, "ymax": 4968100.93, "spatialReference": { "wkid": 102100 } }); //setup the popup window var popup = new esri.dijit.Popup({ marginTop: 35, fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); map = new esri.Map("map", { infoWindow: popup, extent: initExtent }); dojo.connect(map, "onClick", function (evt) { //dispaly popup when users clicks on census3 or census4 layers var query = new esri.tasks.Query(); query.geometry = evt.mapPoint; var def = []; def.push(census4.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW)); def.push(census3.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW)); map.infoWindow.setFeatures(def); map.infoWindow.show(evt.mapPoint); }); dojo.connect(map, "onLoad", mapReady); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"); map.addLayer(basemap); var census = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.dvrpc.org/ArcGIS/rest/services/census/MapServer", { opacity: .65 }); map.addLayer(census); //define popup template for census layer 3 var template = new esri.dijit.PopupTemplate({ title: "Name {NAME00}", mediaInfos: [{ type: "piechart", value: { fields: ["AllWhite", "AllBlk", "AllAsian", "HispTot"] } }] }); census3 = new esri.layers.FeatureLayer("http://gis.dvrpc.org/ArcGIS/rest/services/census/MapServer/3", { mode: esri.layers.FeatureLayer.MODE_SELECTION, infoTemplate: template, outFields: ["*"] }); //define popup template for census layer 4 var template2 = new esri.dijit.PopupTemplate({ title: "Name {NAME}", description: "Descriptive info can go here ....", mediaInfos: [{ type: "piechart", value: { fields: ["TotMale", "TotFem"] } }] }); census4 = new esri.layers.FeatureLayer("http://gis.dvrpc.org/ArcGIS/rest/services/census/MapServer/4", { mode: esri.layers.FeatureLayer.MODE_SELECTION, infoTemplate: template2, outFields: ["*"] }); //add census layers to map in selection only mode. These layers will not be displayed unless selected. map.addLayers([census3, census4]); } function mapReady(map) { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="mainWindow" dojotype="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" design="headline" gutters="true" style="width:100%; height:100%;"> <div id="header" class="shadow" dojotype="dijit.layout.ContentPane" region="top"> <h1>U.S. Census Data Profiles<br><font size=2px;>2005-2009 American Community Survey 5-Year Estimates</font> </h1> </div> <div id="map" class="roundedCorners" dojotype="dijit.layout.ContentPane" region="center"> </div> </body> </html>
//define popup template for census layer 4 var template2 = new esri.dijit.PopupTemplate({ title: "Name {NAME}", description: "Descriptive info can go here ....", mediaInfos: [{ "title": "Male/Female", "type": "piechart", "caption": "Chart caption for male/female chart", "value": { "fields": ["TotMale", "TotFem"] } }, { "title": "Race", "type": "piechart", "caption": "Caption for race chart", "value": { "fields": ["AllWhite", "AllBlk", "AllAsian", "HispTot"] } }] });
Kelly,
Is there not a solution to this issue yet? I am also trying to add a title to my popup template using the setTitle method, with no luck. Adding the title into the content of the popup is not an aesthetically pleasing option. Why is there is method to set the title if it does not work? Thanks.
Chris Bardash if you set the titleInBody popup property to false the title will display in the popup header area. You can do this after creating the map. Here's an example:
var map = new Map("map", { basemap: "topo", center: [-118.4, 34.08], zoom: 14//, //infoWindow: popup }); map.infoWindow.set("titleInBody", false);
That did it. Thank you very much!!!
