how to hide infowindow when measurement widget is active
1906
12-05-2018 09:59 AM
Pa_Lotus
measure-start and end events  works for point or straight line polylines, but this condition fails when it is polygon or an area with multiple edges/corners
 var measurement = new Measurement({
        map: map
    }, dom.byId("measurementDiv"));
    measurement.startup();
    //measurement.on("measure-start", function (evt) {
    //    if (map.infoWindow.isShowing) {
    //        map.infoWindow.hide();
    //measurement.on("measure-end", function (evt) {
Any suggestions?
RobertScheitlin__GISP
Pa_Lotus
Robert,
by using this line it fails to behave as expected
map.setInfoWindowOnClick(true);
Malla,
   You use false when you do not want the popups to show and then use true when you want to restore the popups.
