How to convert a query result into a table in PDF file
2112
07-20-2017 02:37 PM
LeiZhou1
I created a query and queryTask; run the queryTask and get a result (say featureSet) .
Now I need to convert this object (featureSet) to create a PDF report, make it display as a table, like field A, field B, ... as columns.  I know how to loop the feature to get a value, but have no clue how to put them into a table in PDF.  Is there any hint or sample code how to do this? Thanks a lot!
ThomasSolow
You can generate a PDF in the browser using javascript.  There are many third party libraries that can help with this like: GitHub - MrRio/jsPDF: Client-side JavaScript PDF generation for everyone.
I imagine you could build a table based on arbitrary data in a PDF using that library (or another similar one).  I'm unsure if there's an easier way to do this than basically building the PDF from scratch.
ThomasSolow
mattprice
You could also create a geoprocessing tool that takes the data and formats a report in pdf format.
