How do I create a password protected print widget?
1054
05-09-2023 06:49 AM
ChesouyeCoye
I am create a web application and I would like to add a print widget to give them access to print the map or sections of the map. However, I would like it to be password protected so I, as admin can give only certain persons the privilege to do so. Is this possible and how do I go about doing so?
JamesIng
I don't think you can control that level of privileges' inside the Javascript framework.
Depending on what your end goal is - you could simply implement something on the frontend to control whether or not that print widget UI displays whether or not they belong to a group inside ArcGIS or similar.
The printing functionality isn't technically  protected, but unless you expect your users to purposefully circumvent your UI it should be enough in most cases.
James from www.landkind.com
