How do clear all graphics on map with a button click?
9933
11
11-17-2014 09:37 AM
ChrisSergent
I have an image button that I want to use so I can clear all graphics from a map. I thought it might be map.on, but I am not sure what I should write. Here is my code where I tried to clear the graphics from the map on a button click.
<!DOCTYPE html>
<html>
    <head>
        <title>Decatur GIS Template</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
            #HomeButton
                position: absolute;
                top: 95px;
                left: 20px;
                z-index: 50;
            #LocateButton
              position: absolute;
              top: 140px;
              left: 20px;
              z-index: 50;
            #clearGraphicsBtn
                height:20px;
                width:20px;
                position:absolute;
                top:200px;
                left:20px;
                z-index:50;
                padding:5px 6px 5px 6px;
                background-color:Gray;
                border-radius:5px;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            require(["esri/map", "esri/config",
                    "esri/dijit/HomeButton",
                    "esri/dijit/LocateButton",
                    "esri/layers/ArcGISTiledMapServiceLayer",
                    "esri/layers/ArcGISDynamicMapServiceLayer",
                    "esri/tasks/GeometryService",
                    "dojo/dom",
                    "dojo/on",
                    "dojo/parser",
                    "esri/geometry/Extent",
                    "dojo/domReady!"], function (Map, esriConfig, HomeButton,
                                                 LocateButton, ArgGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
                                                 GeometryService, dom, on, parser, Extent
                        // set custom extent
                        var initialExtent = new Extent({ "xmin": 777229.03, "ymin": 1133467.92, "xmax": 848340.14, "ymax": 1185634.58, "spatialReference": { "wkid": 3435} });
                        map = new Map("mapDiv", {
                            showAttribution: false,
                            sliderStyle: "small",
                            extent: initialExtent
                        // add imagery
                        var tiled = new ArgGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                        map.addLayer(tiled);
                        // add operational layer
                        var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                        map.addLayer(operationalLayer);
                        // declare geometry service
                        esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                        // add home button to get full extent
                        var home = new HomeButton({
                            map: map
                        }, "HomeButton");
                        home.startup();
                        // add geolocate button to find the location of the current user
                        geoLocate = new LocateButton({
                            map: map,
                            highlightLocation: true
                        }, "LocateButton");
                        geoLocate.startup();
                    // Clear all graphics from map
                    function clearGraphics() {
                        map.graphics.clear();
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv">
            <div id="HomeButton"></div>
            <div id="LocateButton"></div>
            <div id="ClearGraphicsButton">
                <input type="image" id="clearGraphicsBtn" src="images/nav_decline.png" onclick="clearGraphics()" alt="Clear Graphics" title="Clear Graphics" />
            </div>
        </div>
    </body>
</html>
Tags (1)
JohnRitsko
I'll give this a shot later today, very much appreciated.
JohnRitsko
Robert,
Perfect....solved it and got it working thanks to you.
