disable "searching" or "no results found" infoWindows
966
06-07-2013 09:58 AM
LukePhilips
Is it possible to control/modify/disable the "searching" or "no results found" infoWindow's that pop up when using tasks like the IdentifyTask?
KellyHutchins
Esri Notable Contributor
If you are using the Popup Info Window you could listen for 'onSetFeatures' and if the selected index is not -1 (nothing selected) display the window.  Here's an example: http://jsfiddle.net/Caezz/
