Create Polygon Feature: Java Script
13103
20
01-09-2020 11:27 PM
Vakhtang_Zubiashvili
Hi guys,
I am trying to use ArcGIS API for JavaScript Sandbox this sample to add polygon feature, i also use codes taking from here https://community.esri.com/thread/224031-how-to-create-a-polygon-js-api-49?commentID=811443&et=watch... from   Robert Scheitlin, GISP,   but can not combine this two sample to add polygon and update attributes.
Thank you for your help
Here is a code samples i use (you can see them in links too):
      // Call FeatureLayer.applyEdits() with specified params.
      function applyEdits(params) {
        featureLayer.applyEdits(params).then(function(editsResult) {
          // Get the objectId of the newly added feature.
          // Call selectFeature function to highlight the new feature.
          if (editsResult.addFeatureResults.length > 0) {
            const objectId = editsResult.addFeatureResults[0].objectId;
            //selectFeature(objectId);
// called when sketchViewModel's create-complete event is fired.
        function addGraphic(event) {
          // Create a new graphic and set its geometry to
          // `create-complete` event geometry.
          const graphic = new Graphic({
            geometry: event.geometry,
            symbol: sketchViewModel.graphic.symbol,
            attributes: {}
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Update FeatureLayer using applyEdits() - 4.14</title>
    <link
      rel="stylesheet"
    <script src="https://js.arcgis.com/4.14/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding0;
        margin0;
        height100%;
        width100%;
      #formDiv {
        width100%;
      .esri-item-list__scroller {
        overflow-yvisible;
      .editArea-container {
        background#fff;
        line-height1.5em;
        overflowauto;
        padding12px 15px;
        width300px;
      .list-heading {
        font-weightnormal;
        margin-top20px;
        margin-bottom10px;
        color#323232;
      .or-wrap {
        background-color#e0e0e0;
        height1px;
        margin2em 0;
        overflowvisible;
      .or-text {
        background#fff;
        line-height0;
        padding0 1em;
        positionrelative;
        bottom0.75em;
      /* override default styles */
      .esri-feature-form {
        background#fff;
      .esri-feature-templates {
        width256px;
      .esri-feature-templates__section-header {
        displaynone;
      .esri-feature-templates__section {
        box-shadownone;
      .esri-feature-templates__scroller {
        max-height200px;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/Sketch/SketchViewModel",
        "esri/layers/FeatureLayer",
        "esri/Graphic",
        "esri/layers/GraphicsLayer",
        "esri/widgets/Expand",
        "esri/widgets/FeatureForm",
        "esri/widgets/FeatureTemplates"
      ], function(
        Map,
        MapView,
        SketchViewModel,
        FeatureLayer,
        Graphic,
        GraphicsLayer,
        Expand,
        FeatureForm,
        FeatureTemplates
        let editFeaturehighlight;
        const featureLayer = new FeatureLayer({
          url:
          title:"ქუჩების ფენა",
          outFields: ["*"],
          popupEnabled: false,
        // GraphicsLayer to hold graphics created via sketch view model
      const graphicsLayer = new GraphicsLayer({
        const map = new Map({
          basemap: "dark-gray",
          layers: [graphicsLayerfeatureLayer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          center: [44.750241.725524],
          zoom: 12
        //****************************-სიმბოლოები პოლიგონისთვის-***********************
        const pointSymbol = {
        type: "simple-marker"// autocasts as new SimpleMarkerSymbol()
        style: "square",
        color: "#8A2BE2",
        outline: { // autocasts as new SimpleLineSymbol()
          color: [255255255],
          width: 3
      const polylineSymbol = {
        type: "simple-line"// autocasts as new SimpleLineSymbol()
        color: "#8A2BE2",
        width: "4",
        style: "dash"
      const polygonSymbol = {
        type: "simple-fill"// autocasts as new SimpleFillSymbol()
        color: "red",
        style: "solid",
        outline: {
          color: "red",
          width: 1
        // New FeatureForm and set its layer to 'Incidents' FeatureLayer.
        // FeatureForm displays attributes of fields specified in fieldConfig.
        const featureForm = new FeatureForm({
          container: "formDiv",
          layer: featureLayer,
          fieldConfig: [
              label: "REQ კოდი"
              label: "აბონენტების რაოდენობა"
        // Listen to the feature form's submit event.
        // Update feature attributes shown in the form.
        featureForm.on("submit"function() {
          if (editFeature) {
            // Grab updated attributes from the form.
            const updated = featureForm.getValues();
           // Loop through updated attributes and assign
            // the updated values to feature attributes.
            Object.keys(updated).forEach(function(name) {
              editFeature.attributes[name] = updated[name];
            // Setup the applyEdits parameter with updates.
            const edits = {
              updateFeatures: [editFeature]
            applyEditsToIncidents(edits);
            document.getElementById("viewDiv").style.cursor = "auto";
        // Check if the user clicked on the existing feature
        selectExistingFeature();
        // The FeatureTemplates widget uses the 'addTemplatesDiv'
        // element to display feature templates from incidentsLayer
        const templates = new FeatureTemplates({
          container: "addTemplatesDiv",
          layers: [featureLayer]
        // Listen for when a template item is selected
        templates.on("select"function(evtTemplate) {
          // Access the template item's attributes from the event's
          // template prototype.
          attributes = evtTemplate.template.prototype.attributes;
          unselectFeature();
          document.getElementById("viewDiv").style.cursor = "crosshair";
          // With the selected template item, listen for the view's click event and create feature
          const handler = view.on("click"function(event) {
            // remove click event handler once user clicks on the view
            // to create a new feature
            handler.remove();
            event.stopPropagation();
            featureForm.feature = null;
            if (event.mapPoint) {
              point = event.mapPoint.clone();
              point.z = undefined;
              point.hasZ = false;
              // Create a new feature using one of the selected
              // template items.
              editFeature = new Graphic({
                geometry: point,
                attributes: {
                  IncidentType: attributes.IncidentType
              // Setup the applyEdits parameter with adds.
              const edits = {
                addFeatures: [editFeature]
            } else {
              console.error("event.mapPoint is not defined");
        function applyEditsToIncidents(params) {
          // unselectFeature();
          featureLayer
            .applyEdits(params)
              if (
                editsResult.addFeatureResults.length > 0 ||
                editsResult.updateFeatureResults.length > 0
                unselectFeature();
                let objectId;
                } else {
                  objectId = editsResult.updateFeatureResults[0].objectId;
                if (addFeatureDiv.style.display === "block") {
                  toggleEditingDivs("none""block");
              // show FeatureTemplates if user deleted a feature
              else if (editsResult.deleteFeatureResults.length > 0) {
                toggleEditingDivs("block""none");
            .catch(function(error) {
              console.log("===============================================");
              console.error(
                "[ applyEdits ] FAILURE: ",
                error.code,
                error.name,
                error.message
              console.log("error = "error);
        // Check if a user clicked on an incident feature.
        function selectExistingFeature() {
            // clear previous feature selection
            unselectFeature();
            if (
              document.getElementById("viewDiv").style.cursor != "crosshair"
              view.hitTest(event).then(function(response) {
                // If a user clicks on an incident feature, select the feature.
                if (response.results.length === 0) {
                } else if (
                  response.results[0].graphic &&
                  response.results[0].graphic.layer.id == "incidentsLayer"
                  selectFeature(
                    response.results[0].graphic.attributes[
                      featureLayer.objectIdField
        // Highlights the clicked feature and display
        // the feature form with the incident's attributes.
        function selectFeature(objectId) {
          // query feature from the server
          featureLayer
            .queryFeatures({
              objectIds: [objectId],
              outFields: ["*"],
              returnGeometry: true
            .then(function(results) {
              if (results.features.length > 0) {
                editFeature = results.features[0];
                // display the attributes of selected feature in the form
                featureForm.feature = editFeature;
                // highlight the feature on the view
                view.whenLayerView(editFeature.layer).then(function(layerView) {
                  highlight = layerView.highlight(editFeature);
        // Expand widget for the editArea div.
        const editExpand = new Expand({
          expandIconClass: "esri-icon-edit",
          expandTooltip: "Expand Edit",
          expanded: true,
          view: view,
          content: document.getElementById("editArea")
        view.ui.add(editExpand"top-right");
        // input boxes for the attribute editing
        const addFeatureDiv = document.getElementById("addFeatureDiv");
        const attributeEditing = document.getElementById("featureUpdateDiv");
        // Controls visibility of addFeature or attributeEditing divs
        function toggleEditingDivs(addDivattributesDiv) {
          addFeatureDiv.style.display = addDiv;
          attributeEditing.style.display = attributesDiv;
            "updateInstructionDiv"
          ).style.display = addDiv;
        // Remove the feature highlight and remove attributes
        // from the feature form.
        function unselectFeature() {
          if (highlight) {
            highlight.remove();
        // Update attributes of the selected feature.
        document.getElementById("btnUpdate").onclick = function() {
          // Fires feature form's submit event.
          featureForm.submit();
        // Delete the selected feature. ApplyEdits is called
        // with the selected feature to be deleted.
        document.getElementById("btnDelete").onclick = function() {
          // setup the applyEdits parameter with deletes.
          const edits = {
            deleteFeatures: [editFeature]
    </script>
  </head>
<body>
    <div id="editArea" class="editArea-container esri-widget--panel">
      <div id="addFeatureDiv" style="display:block;">
        <h3 class="list-heading">Report Incidents</h3>
        <ul style="font-size: 13px; padding-left: 1.5em;">
          <li>აირჩიეთ ფენა ჩამოათვალიდან</li>
          <li>დააწკაპეთ რუკაზე რომ დაამატოთ ახალი ობიექტი</li>
          <li>დაკავშირებული მონაცემების ატვირთვა</li>
          <li>დააწკაპეთ <i>მონაცემების ატვირთვა</i></li>
        </ul>
        <div id="addTemplatesDiv" style="background:#fff;"></div>
      </div>
      <div id="featureUpdateDiv" style="display:none; margin-top: 1em;">
        <h3 class="list-heading">შეიყვანეთ ინციდენტის ინფორმაცია</h3>
        <div id="attributeArea">
          <div id="formDiv"></div>
          <input
            type="button"
            class="esri-button"
            value="მონაცემების ატვირთვა"
            id="btnUpdate"   />
        </div>
        <br />
        <div id="deleteArea">
          <input
            type="button"
            class="esri-button"
            value="წაშალეთ ინციდენტი"
            id="btnDelete" />
        </div>
      </div>
      <div id="updateInstructionDiv" style="text-align:center; display:block">
        <p class="or-wrap"><span class="or-text">ან</span></p>
        <p id="selectHeader">მონიშნეთ ინციდენტი რომ წაშალოთ ან შეცვალოთ.</p>
      </div>
    </div>
    <div id="viewDiv"></div>
  </body>
</html>
RutujaPatwardhan
Based on the TIOBE Index for June 2016 Java is now more well-known than a variety of widely-used programming languages, including C++, Python, C#, PHP and JavaScript. The statistics on usage posted on various websites illustrate the immense popularity and importance of Java in the present day world. Java is an all-purpose programming language. Certain developers prefer to use Java to build desktop GUI applications as well as other developers create numerous web-based applications using Java technologies. In addition, Java is also used extensively for the development of mobile applications and games for Android which is the mobile platform with the biggest user base. There are plenty of reasons that Java is going to be a major factor over an extended period of time.
visit: Java Course in Pune
