Checkbox Change Div _ TOC
2615
08-25-2014 09:11 AM
CraigLinn
I am trying to discover a way to hide my div "layerTitle" if no TOC check boxes are selected. Any suggestions would be awesome!!
<!DOCTYPE html>
<html>
<head>
    <title>Map</title>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <link rel="stylesheet" type="text/css" href="http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs/css/agsjs.css" />
    <style>
        html, body {
            height: 100%;
            width: 100;
            margin: 0;
            padding: 0;
            font-family: helvetica, arial, sans-serif;
            font-size: 90%;
   color: #00151;
       #map {
            padding: 0;
   overflow: hidden;
   background-color:#0072AF; color:#0072AF;
   #header {
      margin:0px;
      padding: 0px;
   text-align:right;
    background: -webkit-gradient(linear, left top, left bottom, from(#005b8c), to(#1980b7));
      border: solid 1px #000000;
      height: 56px;
#bookmarks-wrapper {
        position: absolute;
        z-index: 40;
        top: 15px;
        right: 30px;
        background: transparent;
        font-size: 12pt;
        color: #444;
   #Search-wrapper {
        position: absolute;
        z-index: 40;
        top: 15px;
        right: 140px;
        font-size: 12pt;
        color: #444;
     #RssLayers-wrapper {
        position: absolute;
        z-index: 40;
        top: 15px;
        right: 265px;
        font-size: 12pt;
        color: #444;
#title {
      font-size:150%;
      color: #ffffff;
      text-align:center;
   margin: 2px;
    #subfooter {
      font-size:small;
      color: #ffffff;
   font-size:13px;
      text-align:center;
   margin: 2px;
    .esriControlsBR {
   display: none;
#layerTitle {
font-family: "Times New Roman", Times, serif;
font-size: 18px;
font-style: bold;
color: rgb(255, 255, 255);
vertical-align: middle;
padding: 5px;
top: 10px;
right: 35%;
position: absolute;
z-index: 50;
height: auto;
width: auto;
background-color: rgb(72, 99, 160)!important;
border-style: solid;
border-width: 1px;
border-radius: 5px;
opacity: 0.8;
text-align: center;
     #RssLayers-wrapper { display:none; }
        /* this line hides layers when out of scale for the inline TOC
        .agsjsTOCOutOfScale {
            display: none
    </style>
    <script type="text/javascript">
        var djConfig = {parseOnLoad: true, packages: [{"name": "agsjs","location": "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs" }] };
    </script>
    <script src="http://js.arcgis.com/3.8/"></script>
        var map, toc, dynaLayer1;
        require(["dojo/_base/connect",
                 "dojo/parser",
      "esri/urlUtils",
      "dojo/on",
      "agsjs/dijit/TOC",
                 "esri/map",
     "esri/layers/ArcGISDynamicMapServiceLayer",
       "esri/InfoTemplate",
       "dojo/_base/array",
       "dijit/form/CheckBox",
       "dojo/dom",
       "dojo/dom-construct",
      "dijit/form/DropDownButton",
      "dijit/form/Button",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
                 "dojo/fx",
                 "dojo/domReady!"],
                 function (connect, parser,urlUtils, on, TOC, Map, ArcGISDynamicMapServiceLayer, InfoTemplate,array,  CheckBox, dom, domConstruct) {
                     //call the parser to create the layout dijits
                     parser.parse();
                     map = new Map("map", {
                         center: [-101.00, 45.768],
                         zoom: 6,
                         basemap: "streets"
///Proxy
// Dyanmic layer For Table of Contents
                     dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://maps5.gisworkshop.com/ArcGIS/rest/services/McKenzieTaxDirector/MapServer", {
                     map.on('layer-add-result', function (e) {
                         dynaLayer1.setVisibleLayers([0]);
                         toc = new TOC({
                             map: map,
                             layerInfos: [{
                                 layer: dynaLayer1,
                                 title: "McKenzie Parcels",
                                 collapsed: true,
                                 slider: false
                         }, 'tocDiv');
                         toc.startup();
                     map.addLayer(dynaLayer1);
  dojo.connect(dynaLayer1, "onUpdate", showInfo);
///////////// Check-Box Created////////////////////////////////////
        map.on('layers-add-result', function () {
          //add check boxes
          arrayUtils.forEach(legendLayers, function (layer) {
            var layerName = layer.title;
            var checkBox = new CheckBox({
              name: "checkBox" + layer.layer.id,
              value: layer.layer.id,
              checked: layer.layer.visible
            checkBox.on("change", function () {
              var targetLayer = map.getLayer(this.value);
              targetLayer.setVisibility(!targetLayer.visible);
              this.checked = targetLayer.visible;
            //add the check box and label to the toc
            domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");
            var checkLabel = domConstruct.create('label', {
                'for': checkBox.name,
                innerHTML: layerName
              }, checkBox.domNode, "after");
            domConstruct.place("<br /><hr>", checkLabel, "after");
/////////////////////ENd CHeckBOx///////////
     }); // End Main Function ///////
// Show TITLE based on CheckBox Selected
function showInfo(){
    var visibleLayers =  dynaLayer1.visibleLayers;
  dynaLayer1.layerIds = visibleLayers;
    if (dynaLayer1.visibleLayers =='0'){
  dojo.byId("layerTitle").innerHTML = ('Layer 0');
  else if (dynaLayer1.visibleLayers =='1'){
  dojo.byId("layerTitle").innerHTML = ('Layer 1');
  else if (dynaLayer1.visibleLayers =='2'){
  dojo.byId("layerTitle").innerHTML = ('Layer 2');
  else if (dynaLayer1.visibleLayers =='3'){
  dojo.byId("layerTitle").innerHTML = ('Layer 3');
    </script>
</head>
<body class="tundra">
    <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
<div id="header" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
   <div id="title">Title Main
       <div id="subfooter">SubTitle</div>
    </div>
<!-- Bookmarks widget inside a Drop Down Button -->
        <div id="bookmarks-wrapper">
   <div data-dojo-type="dijit/form/DropDownButton" region="top"> <span>Layers</span>
    <div data-dojo-type="dijit/TooltipDialog">
    <div id="tocDiv"></div>
    </div>
    </div>
  </div>
<!-- Search widget inside a Drop Down Button -->
</div><!-- End Header -->
   <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">
   <div id="layerTitle"></div>
        </div> <!-- End Map-->
    </div>
</div>
</body>
</html>
Tags (3)
RobertScheitlin__GISP
Craig,
  You have a lot of work to do here but here is your code working with turning your div off if there is no visible layers:
<!DOCTYPE html>
<html>
<head>
    <title>Map</title>
    <style>
        html, body {
            height: 100%;
            width: 100;
            margin: 0;
            padding: 0;
            font-size: 90%;
  color: #00151;
      #map {
            padding: 0;
  overflow: hidden;
  #header {
      margin:0px;
      padding: 0px;
  text-align:right;
      height: 56px;
        position: absolute;
        z-index: 40;
        top: 15px;
        right: 30px;
        font-size: 12pt;
        color: #444;
  #Search-wrapper {
        position: absolute;
        z-index: 40;
        top: 15px;
        right: 140px;
        font-size: 12pt;
        color: #444;
        position: absolute;
        z-index: 40;
        top: 15px;
        right: 265px;
        font-size: 12pt;
        color: #444;
#title {
      font-size:150%;
      color: #ffffff;
      text-align:center;
  margin: 2px;
    #subfooter {
      font-size:small;
      color: #ffffff;
  font-size:13px;
      text-align:center;
  margin: 2px;
    .esriControlsBR {
  display: none;
#layerTitle {
font-size: 18px;
font-style: bold;
padding: 5px;
top: 10px;
right: 35%;
position: absolute;
z-index: 50;
height: auto;
width: auto;
border-width: 1px;
border-radius: 5px;
opacity: 0.8;
text-align: center;
            display: none
    </style>
    </script>
                "dojo/parser",
                "esri/urlUtils",
                "dojo/on",
                "agsjs/dijit/TOC",
                "esri/map",
                "dojo/_base/array",
                "dojo/dom",
                "dojo/_base/html",
                "dojo/fx",
                "dojo/domReady!"],
                function (connect, parser, urlUtils, on, TOC, Map, ArcGISDynamicMapServiceLayer, InfoTemplate, array, CheckBox, dom, html, domConstruct, fx) {
                    parser.parse();
                        zoom: 6,
                        basemap: "streets"
///Proxy
                        toc = new TOC({
                            map: map,
                            layerInfos: [{
                                layer: dynaLayer1,
                                collapsed: true,
                                slider: false
                        }, 'tocDiv');
                        toc.startup();
          //add check boxes
/////////////////////End CheckBox///////////
          html.setStyle(dojo.byId("layerTitle"), 'display', 'block');
          var visLayers = "Layer(s): ";
          dojo.byId("layerTitle").innerHTML = visLayers + visibleLayers.toString();
          if(dynaLayer1.visibleLayers[0] == -1){
            html.setStyle(dojo.byId("layerTitle"), 'display', 'none');
    </script>
</head>
        </div>
          <div data-dojo-type="dijit/form/DropDownButton" region="top"><span>Layers</span>
            </div>
          </div>
        </div>
  </div>
</body>
</html>
CraigLinn
Thank you,  I was able to tweak your suggestion and apply it to my situation.
