Zone Lookup Results not capturing all mapped data in buffer
389
09-23-2024 10:07 AM
ShariF
Hi GIS'ers.
I've been asked to develop a tool that would create a 1/4 mile buffer and then create a report that would list all mapped items within that buffer (points, lines and polygons). I thought the Zone Lookup Instant App would be my saving grace instead of slogging thru a python script tool.
I have everything configured in the map and the app, and I am not getting the expected results when I use the line tool and a 1/4 mile buffer.  I've chosen "Feature Within a Zone" and the spatial relationship is "Intersects" all of the following:
Yet the results are missing some of the polygons (Current Land Use for example).
However, when I use the point and a radius, it only puts the polygon layers:
Ideally I want all of the above layers to show when I use the line tool. Is that possible?
You can check out the app here
Thank you.
SarahNoakes1
Hi @ShariF,
There is currently an issue with the intersects option of the Zone Lookup Instant App - see Re: Instant app zone lookup spatial relationship I... - Esri Community.  A bug has been logged BUG-000170803 and it has the status of "In Product Plan" which apparently means it will be addressed in the next release or two.
SarahNoakes1
Hi @ShariF,
ShariF
Thanks Sarah for the update.
KellyHutchins
Esri Frequent Contributor
The fix for this issue is scheduled to go out in the next release of ArcGIS Online later this year.
