Timeline showing in Map Viewer, but not in the slider Instant App
1038
10-30-2024 05:24 AM
MaggieOwen
Hello! I have been running into this issue where I make a timeline in Map Viewer, the timeline is showing and everything looks normal, but then when adding my map to the Slider Instant App -the timeline isn't showing up.
I try refreshing, removing and re adding the map, making a new Instant App all together -I've even remade the map thinking maybe that would help.
It didn't used to do this, a month or so ago the timeline was showing up at the bottom of the Instant App as normal. This has been a new issue I have encountered this past week.
Any help would be so appreciated!
KellyHutchins
Esri Notable Contributor
It's not the layers in the map its the tables. If you look in the map viewer you'll see there is a separate table section and that is where you'll see a bunch of tables with ! icons next to them saying they didn't load.
KellyHutchins
@MaggieOwen it looks like there are some tables in your web map that are not loading and those layers are causing an issue when the app loads preventing the slider from displaying.
If you remove the tables that are not loading and save your map the app should load the time slider.
MaggieOwen
Hi, thanks so much for your response! So, there's only 2 layers in the map. One is the outline for the state, and the second is the polygon layer. I suspect the polygon layer is too large and that could be why the time slider isn't showing, though the polygons seem to be mapping fine...
KellyHutchins
MaggieOwen
My mistake! Thank you so much for your help!
