Starting the 3D Viewer App with custom viewpoint (similar to a scene &viewpoint=cam:<coordinates>)
2280
02-22-2023 02:39 AM
Pål_Herman_Sund
Hi
with a Scene one can provide the "&viewpoint=cam:<coordinates> " as a URL parameter to have a custom viewpoint. Is it possible to build similar URL for starting the 3D Viewer App with a custom Viewpoint?
best
Pål Herman
KellyHutchins
Esri Notable Contributor
I ran a quick test with a local scene and it worked for me. Perhaps its something with your local scene. If its public can you send me the link and I can take a look?
https://jsapi.maps.arcgis.com/apps/instant/3dviewer/index.html?appid=93730225fcb54e658851159cda059a7...
KellyHutchins
Yes you can use a custom viewpoint via url param to load the app at a particular viewpoint. Here's an example:
https://www.arcgis.com/apps/instant/3dviewer/index.html?appid=4e8c21a7013c454caf04a99369e481fd&viewp...
An easy way to generate the url is to use the share tool in the upper right corner of the app. If you set pan/zoom/rotate to get the map the way you want it then click the Share > Copy Link it will copy a link to the clipboard with the custom viewpoint.
Pål_Herman_Sund
Thanks @KellyHutchins I did notice that text in the documentation, maybe I am troubling but I can only get that "viewpoint-thing" to function when the underlying scene is a global one.
KellyHutchins
Pål_Herman_Sund
Thanks again @KellyHutchins I was of course working in a scene with EPSG:25833 refsys and have to add the EPSG code into the URL parameters. Can not share the scene but these parameters are fine:
&viewpoint=cam:-30000,6733000,400,25833;0,90 (being X,Y,Z,EPSG code, direction/azimuth, camera angle)
Many thanks for prompt reply's - much appreciated 🙂
best
Pål Herman/pH
