Search not working at certain scale for addresses beyond extent
444
11-05-2021 10:50 AM
jadams
When searching for address when zoomed in (often the case if you are looking up a second address after an initial search), it appears that there are 'no results found' if the address is beyond the extent of the map. Even if you select a suggested address. It works fine if you zoom out to a town scale (even if it's beyond extent.) Is this a bug?
KellyHutchins
Esri Frequent Contributor
Looks like a bug. We'll get it addressed in the next release of online. In the meantime a potential workaround would be to enable the "Hide layers when app loads" option in the Zone Lookup section.
KellyHutchins
jadams
Thanks for the quick reply! That works.
