Nearby App: Distance Slider
825
07-07-2021 09:25 AM
DanteLee
Occasional Contributor II
Is there a way to control the granularity of the distance slider/radius search? By default it goes down to the thousandth decimal, and it's really hard to get it to the desired number. As a workaround, I've toggled the "Change min and max search distance" option that allows users to manually enter in a number. This works for this current app, but it doesn't work for apps where I want to control the max search radius.
KellyHutchins
Esri Frequent Contributor
I want to make sure I understand the issue. Are you asking to have control over the decimal places? So it would just show 283 ft vs 283.194? If so that is something we can look at exposing via the configuration in a future release.
DanteLee
Yes! The 3 decimals are excessive imo. I suspect someone in the future might also ask for interval control (e.g. every 5 miles)
KellyHutchins
Ok thanks. I'll add an enhancement for this and we can look at it for the fall release.
