How do I change the title field for related records in Reporter Instant App?
213
09-03-2025 07:27 AM
Cepero_Eudel
Hi everyone,
I’m using the Reporter Instant App to show related inspection records, but the default title is the Flagged field (“Yes”/“No”), which isn’t helpful. I’d like to display something more meaningful like Inspection Date, Deficiency Description, or Status.
Is there a way in the app settings to change which field is used as the title? I only see toggles for Reporting, Comment, Like, etc., but no field selector. Any ideas?
BethRomero
@Cepero_Eudel The related record has a pop-up which can be configured in the map. The pop-up drives what is visible when someone views a comment/related record . Editing this in the map viewer will allow you to change the title, and you can also configure an edit form to customize the edit (comment submission) experience as well.
BethRomero
