Crowdsource Polling Comment Box Height
704
07-13-2017 11:54 PM
JenniferSmits
New Contributor II
For collecting comments on the Crowdsource Polling Web App, is it possible to increase the size of the comments field box (the height)? In my map, as default, users can enter up to 7000 characters, but must do so all in one line. They then find it difficult to review and edit what they previously typed? Is it something that is available in other templates?
Thanks-Jen
AllisonMuise1
Jennifer Smits‌ Yes, you can make the box larger by editing the popup configuration of the related table.
1. In the web map, click the three dots that appear when you hover over the name of the table and click Configure Popup.
2. In the popup configuration panel, click the Configure Attributes link.
3. Choose the field you'd like to expand and choose the Multi-Line TextBox Type from the Editing settings on the right-hand side of this window.
You can also use this panel to update the field aliases shown in the form, the order of the fields, and other didsplay settings.
-Allison
AllisonMuise1
-Allison
JenniferSmits
New Contributor II
Thank you Allison. That worked perfectly! So easy.
