Attachment Viewer: Attachments in Related Tables Aren't Supported?
709
03-15-2023 08:14 AM
ArmstKP
I have an ArcGIS Server service where I have a related inspection table with attachments enabled. The Attachment Viewer does not support this?  The attachments have to be related to a feature class, not the related table?
SarahMcDonald_Esri
Hello,
Thanks for reaching out about this. Attachment Viewer can support viewing attachments in a related table, but the table needs to be related to a Feature layer that also has attachments enabled. This should also be supported with ArcGIS Server services. What version of ArcGIS Enterprise are you using?
Thanks!
Sarah
FourCornersMapping
@SarahMcDonald_Esri I have not found a way to view attachments in a related table, i.e. from a Survey123 hosted feature layer with a related photos table, even with enable attachments toggled on for both the layer and the table. Do you have a suggestion for me? I would love if the Attachment Viewer app could support viewing photos via a related table, like the Survey123 data tab does.
