ArcGIS Instant Apps Questions
106
3.4M
732
Open | currently, the filter function on layer attributes only works with an 'equals' operator (as a default, no other optio... by Josef_Strobl Frequent Contributor 0 0 | 0 | 0 | |
Open | This is specifically for instances when you configure the map to remove all the fields from the popup and just have a... by JAVT Emerging Contributor 0 0 | 0 | 0 | |
Open | The description of the Exhibit app says that, "For each slide, you can change layer visibility." But it looks like th... by TWChi Occasional Contributor 0 0 | 0 | 0 | |
Open | Automatically apply the organisation’s or layer’s date format settings to the filter and pop-ups in Instant Apps. Or,... by Bryan_krg Emerging Contributor 1 0 | 1 | 0 | |
Open | The compare instant app is a great creation for quickly serving out an application for comparing two or more maps.I c... by Nick_Creedon Frequent Contributor 0 1 | 0 | 1 | |
Open | It would be very helpful if a cover page could be toggled on or off based on a value from a table in the webmap that ... by KAMPRB Occasional Contributor 0 0 | 0 | 0 | |
Open | Our users really like the functionality and ease of selecting their name using a category selector in the Dashboards,... by RodP Emerging Contributor 1 0 | 1 | 0 | |
Open | It would be great if I could use a URL parameters with the Public Notification Instant App. I would like pass along ... by LeonS Frequent Contributor 0 0 | 0 | 0 | |
Open | It would be fantastic if one could manually enter a zoom scale under the Additional search options rather than using ... by BenWilkersonJC Emerging Contributor 2 1 | 2 | 1 | |
Open | Using Instant Apps and Zone Lookup, when a user searches an address, the "Map pin and label" are not effectively util... by TravisScottpasa Occasional Contributor 1 2 | 1 | 2 | |
Open | When using Instant Apps with Zone Lookup, the setting "Set Scale Level" restricts the users experience to a single zo... by TravisScottpasa Occasional Contributor 1 0 | 1 | 0 | |
Open | Appreciate all of the hard work that has been put into the new Reporter App and it runs very smoothly! We used to use... by AidanMcCullough Emerging Contributor 1 0 | 1 | 0 | |
Open | Currently in ArcGIS Online Instant Apps, there is an option to turn on and off the Layer List. I would like to see t... by TravisScottpasa Occasional Contributor 4 0 | 4 | 0 | |
Open | To start, I really like the new Reporter app compared to CrowdSource Reporter! It's much nicer looking and more respo... by BrendanMadden Occasional Contributor 3 1 | 3 | 1 | |
Open | The Filter Widget in Web App Builders has the capability to list values based on a previous expression. This allows t... by AryamanBhattacharya_BeansAI Emerging Contributor 0 0 | 0 | 0 |
Idea Submission Guidelines
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
