Where can I change the range of the box plot chart?
621
10-06-2022 03:48 PM
Grettel_geo
I have a dataset with values already precalculated to create a box plot graph but the Max value is taken as an outlier, how can I change the range or remove the outliers?
Thank you
Ed_
by MVP Regular Contributor
If VALORES is a column in your dataset, then you can use a `predefine filter` and select `VALORES` to change the y-axis range. Hope this helps.
Cheers
Question | Analyze | Visualize
Ed_
Cheers
Grettel_geo
Thank you @Ed_ for your help.
