Popup change in Insights
1145
10-01-2020 07:27 AM
EricS
I cant find where I can change the pop-up in a map display.  I want to change the popup from Northing: 42 to a different field.  See pic below
ScottSandusky
Hi Eric,
You can change the primary display field within the data pane.  This is described here - View pop-ups—ArcGIS Insights | Documentation
You may also be interested in using the attributes tab.  this is described here - Create a map—ArcGIS Insights | Documentation
let me know if this doesn't answer completely.
ScottSandusky
Hi Eric,
